independent clock FIFO
Hi all
I have generated an asynchronous FIFO using the core generator, set the write clock to 125MHz and read clock to 50Mhz then i statrted to simulate the generated memory using modelsim. First i assert the reset input and then deasset it, set the din value and assert the wr_en and write some words then i deassert the wr_en, the problem is that the empty flag remains high and valid remains zero which means i can not read from the FIFO altough i have writen some words.
Any help ?
Thanks in advance
Instructor
Instructor
Re: independent clock FIFO
One of the most common problems with simulating Xilinx IP including cores
and primitives, is forgetting to wait 100 ns after simulation starts to account
for global set & reset (GSR).  Another one that pops up in Verilog, but is
related to this issue, is to forget to assign a `timescale directive to the
test bench.  I think the default for ModelSim is either picoseconds or
femtoseconds, so if you have #100 to wait for end of GSR you're not
really waiting 100 nanoseconds, but 100 of whatever ModelSim defaults
the time scale to.  If you can see from your waveform that you have
waited at least 100 ns before releasing rst and asserting wr_en,
then maybe you can post a waveform to show what's happening.
-- Gabor
-- Gabor
Observer mroberto
Also, you need to wait for the signal FULL to go low, check this post:
http://forums.xilinx.com/t5/Simulation-and-Verification/LogiCORE-IP-FIFO-Generator-v9-1/m-p/272814
Marcelo.
