invoke axi bfm api inside class in systemverilog
i am using axi bfm to verify my axi ip. now i want to model my ip with a class where the methods will do read/write of my ip. The methods should wrap the axi bfm api functions. But how to do this? I first thought of inheritance but this does not work.
Example:
class myip;
task setregister;
axi_bfm.write_burst(...); // axi-bfm api
endtask
endclass
Re: invoke axi bfm api inside class in systemverilog
You should get the entire hierarchy for this to work.
Sikta
It should be like, for example.
dut.bfm_processor.bfm_processor.cdn_axi4_lite_master_bfm_inst.SEND_WRITE_DATA(4'b1111,'h00000001);
If your method can maintain the hierarchy then you should be able to do this.
Debraj
