qweqwe077
isim do not work with `default_nettype directive
Hello. I am using ISE14.7. I have my verilog module with directive `default_nettype. And I can synthesize module. When I try to run isim - it return error :
FATAL_ERROR:Simulator:CompilerAssert.h:40:1.29 - Internal Compiler Error in file ../src/VlogDecl.cpp at line 1483 For technical support on this issue, please visit http://www.xilinx.com/support.
If I comment directive `default_nettype - all work fine. How can I run simulate with this directive? How can I know in verilog file, if we run simulation or not? (then, I can use `ifndef directive to on/off directive `default_nettype). Or, may be there are any more variants to do this? (The way to use `define - to comment and uncomment when I do simulate or synthesize  - doesn`t suit me.)
graces
You may want to try XILINX_ISIM macro to control whether or not ISIM is used in the design flow. It is a Verilog predefined-macro. The value of this macro is 1.
Example:
module
isim_predefined_macro;
integer fp;
initial
begin
`ifdef XILINX_ISIM
$display("XILINX_ISIM defined");
fp = $fopen("ISIM.dat");
`else
$display("XILINX_ISIM not defined");
fp = $fopen("other.dat");
`endif
$fdisplay (fp, "results");
end
endmodule
graces
Example:
module
integer fp;
initial
begin
`ifdef XILINX_ISIM
`else
`endif
end
endmodule
