issue implementing xapp524 ISERDES2 in MSB first DDR 2 wire bytewise for ADC
I'm currently implementing a LVDS interface for ADC using ISERDES2.
I have based my development on the XAPP524 and its associated design but I'm facing an issue during bit alignement.
I'm in 2 wire mode, DDR, bytewise and MSB first.
I have try some modification on design but I'm bloked.
Patern F0F0 is found but even bits arrive 1 clockdiv before odd bits.
I have used a ramp an data to put in evidence this fact.
double nibble is for 16bits 1 wires so is not activated, and I'm not sure it is the problem.
what should I do to make my design working?
Best regards
Christian
Re: issue implementing xapp524 ISERDES2 in MSB first DDR 2 wire bytewise for ADC
depending the use frequency iserdes "_p" and iserdes "_n" doesn't start on the same clk_div after CE1.
serdes on inverted clock start with 1 clkdiv delay compare to other serdes.
anyone have an idea to correct that issue?
