mif could not be opened
ISim P.15xf (signature 0x8ddf5b5d)
This is a Full version of ISim.
Time resolution is 1 ps
Simulator is doing circuit initialization process.
Block Memory Generator CORE Generator module loading initial data...
WARNING: at 0 ps: file fir_fft_coe_calc_win_exp_ram.mif could not be opened
ROM has been initialized by coe file. The project was created in PlanAhed in Linux.
Re: mif could not be opened
The .mif file is generated by coregen and used in behavioral simulation only. This file needs to be placed in the directory where you launched simulation.
It seems PlanAhead doesn't handle the file very well.
http://forums.xilinx.com/t5/PlanAhead/can-t-open-mif-files/td-p/228733
You might manually copy it there.
