modifying source files during simulation
Hi all
When using modelsim, If a source file is changed you can simply write the restart command in the tcl console in order for the simulator to include the changes.
For ISIM when using GUI. When i change a source file a have to use the relauch command which parses all files from the beginning to update the executable file. Simulating a large design including post synthesis unisim simulation models takes a long time to relaunch the simulation. Is there any way to make the simulator parse and compile the only changed file ?
I use vhpcomp in the tcl console but then i have a use the relaunch command which parses all files again !!
I'm using ISIM with ISE13.3. Using the project file method to generate the executable file then i launch the simulation using the -gui option.
Thanks in advance
Re: modifying source files during simulation
Try using the switch -incremental next time when you run fuse next time. I think you are using a command line flow. For Details refer ISIM User Guide for switch description and usage.
Debraj
Does the incremental switch takes effect when using the relaunch button within the Isim GUI ?
Because the relaunch effectively runs the fuse again !
If you run re-launch it would run fuse without fail. But the fuse would have the switch present only when you have enabled it in Simulation Properties :
fuse.exe -relaunch -intstyle "ise" -incremental -lib "unisims_ver" -lib "unimacro_ver" -lib "xilinxcorelib_ver" -o "/testbench_isim_beh.exe" -prj "/testbench_beh.prj" "work.testbench" "work.glbl"
Ensure you have kept the -incremental switch ON in the Simulate Behavioral Model Properties in GUI.
Debraj
