multiple pulses when using the post-route simulation
Hello,  I have the Ready signal (please see attached files) which is must be last a single clock cycle to indicate that the output data are ready to be read. I got this signal correct when I use the behavioral simulation but when I use the post route simulation,  I got multiple pulses for the Ready signal, which is not right.
any ideas about what causes this?
many thanks,
Post-route simulation uses xilinx primitives. If it is timing simulation then hold and setup time delays should be considered. Will it be possible for you to share your design?
Harika.
@Sultan1
"I got multiple pulses for the Ready signal, which is not right."
Why is not right ?
In a synchronous circuit it is normal for the signals to have glitch.
The only important thing is that they meet setup/hold times.
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
