multiple pulses when using the post-route simulation
Hello,  I have the Ready signal (please see attached files) which is must be last a single clock cycle to indicate that the output data are ready to be read. I got this signal correct when I use the behavioral simulation but when I use the post route simulation,  I got multiple pulses for the Ready signal, which is not right.
any ideas about what causes this?
many thanks,
Post-route simulation uses xilinx primitives. If it is timing simulation then hold and setup time delays should be considered. Will it be possible for you to share your design?
Harika.
Voyager
Voyager
@Sultan1
"I got multiple pulses for the Ready signal, which is not right."
Why is not right ?
In a synchronous circuit it is normal for the signals to have glitch.
The only important thing is that they meet setup/hold times.
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
