netlist simulation
For FPGA synthsis, I am using synopsys synplify tool 2013.
And for the reset of things (BUILD, Place and Route and Timing) using ISE tool
What are the inputs required to simulate the  Post synthesis and Post P&R netlist.
When i am tried to complie the post synthesis netlist ( synplify output  *.vm file is move to *.v file) with Xilinx unisim libs and secureip libs getting the following error
ncelab:  *E  ERRIPR:  error with in protected source code.
Kindly help me.
Thanking you,
Re: netlist simulation
This is simulation query please ask in simulation forum you will get better help there.
Yash
Which version of IES are you using? Is it supported with the ISE version you are using? You can refer to synthesis and simulation Design guide for supported version details.
It looks like you are using multiple step process. Did you pre-compile the libraries for IES using compxlib tool?
Refer to Appendix-B of http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/sim.pdf for more details.
Deepika.
Deepika.
