non stable IDELAYE2 simulation
I'm trying to simulate my LVDS receiver for a 16bit DDR ADC,
the receiver is made of an IBUFDS, an IDELAYE2 and an IDDR for each +/- LVDS pair.
The delay inserted by the IDELAYE2 object is changing through the simulation run: it starts with a ~600ps value (which is apparently default for 7series) than moves to 4000ps then comes back to 600ps, although I am applying a constant value (0) to all of them, and I also make sure the IDELAYCTRL is declared as locked before checking the data. This is not really a problem but the decoded data is therefore not stable and rubbish
 I am not sure what might be causing this behaviour, any guesses?
EDIT:
I was using the "VAR_LOAD" opmode, that is, CNTVALUEIN is loaded any time "LD" is '1'
Switching to "FIXED" opmode with a default CNTVALUE fixes the problem
So I might be doing something wrong with my Load interface:
  • LD is high for one clock cycle & latches CNTVALUE
  • loading causes IDELAYCTRL to RESET and RST is held for many nanosecs (not sure reseting this guy is needed)
  • The test bench now loads a default CNTVALUE for all IDELAY but the problem is still there
  • The test bench does not check CNTVALUEout (make sure CNTVALUEin was properly latched as expected)
G.W.,
NIST - Time Frequency metrology
Re: non stable IDELAYE2 simulation
Problem solved
my bad, I unintentionally tied 'CE' to '1' as I was probably thinking of 'Clock enable' when I did it, but CE/LD/C are part of the loading interface
so the simulation works fine for both FIXED/VAR_LOAD modes of operation
G.W.,
Problem solved
G.W.,
