output waveform is not being generated in model sim for DES algorithm. Is there any way to fix it?
We have attached the verilog code and test bench for Data encryption standards algorithm and are not getting the waveform even though they are showing zero errors..
Re: output waveform is not being generated in model sim for DES algorithm. Is there any way to fix it?
回复: output waveform is not being generated in model sim for DES algorithm. Is there any way to fix it?
How did you launch simulation? Can you see signal objects to be added to waveform?
