patches breaking compile_simlib so it doesn't precompile IP catalog
Does anyone know how to run vivado without using the patches from the /patches directory?
I'm seeing an issue in all versions of Vivado where installing a patch that modifies the IP catalog changes the behaviour of "compile_simlib" so that it doesn't detect the IP from the catalog, it only detects unisim and the IP in the patch.
It's only possible to precompile the IP catalog with versions of vivado that do not patch the IP catalog.
Re: patches breaking compile_simlib so it doesn't precompile IP catalog
Hi @jparsonsciena,
If you want to start Vivado without using a patch, just remove or rename the patch. This will stop the tools being able to find it.
Let me know if I can help further.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Which Vivado version did you use? This issue should have been fixed in 2017.3.
I have the issue with:
2017.3.1 AR70219
2017.3 AR70219
2016.4 AR962576
2016.4 AR68420
2016.3 AR68069
removing the patches to just run compile_simlib isn't an option for me
