ridsarora
problem in harware implemenatation of multiplier
I am trying to do the hardware implemenation of multiplier but i am getting ceratin error in my code(verilog code)...which i also attach it with my code...
muzaffer
you need to put the brackets on the right hand side of the identifier when you use them, ie:
wire [3:0] a, b;
assign b[3:0] = a[3:0];
debrajr
@ridsarora Please feel free to mark the post which has helped you as an accepted solution for other community members/visitors. Its a good forums practice.
Debraj
