Participant zuweihan1992
problem launching modelsim with vivado 2013.4
Hi everyone,
I am a new and I am trying to launch modelsim on vivado according to this website:
http://www.xilinx.com/training/vivado/simulating-with-modelsim-in-vivado.htm
However, it always said :
ERROR: [Vivado 12-2180] No simulator specified for compilation ...
compile_simlib tcltask - end ... (1)
ERROR: [Common 17-39] 'compile_simlib' failed due to earlier errors.
when I type compile_simlib on TCL console. So I tried to find a soultion  from the Internet and I found from here:
http://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-compile-simlib-problem/m-p/348373
that I need to use this instruction:
compile_simlib -simulator modelsim -simulator_exec_path PATH
PATH -- path to modelsim executable
And it can execute modelsim correctly when I press "Run Behavioral Simulation". But there is always a mistake when executing the modelsim (in the attachments).
And the program for that line is:
vsim -voptargs="+acc" -t 1ps -L unisims_ver -L unimacro_ver -L secureip -L blk_mem_gen_v8_1 -L fifo_generator_v11_0 -L proc_common_v4_0 -L axi_lite_ipif_v2_0 -L interrupt_control_v3_0 -L axi_gpio_v2_0 -L proc_sys_reset_v5_0 -L generic_baseblocks_v2_1 -L axi_data_fifo_v2_1 -L axi_infrastructure_v1_1 -L axi_register_slice_v2_1 -L axi_protocol_converter_v2_1 -lib work sim_wrapper glbl
Can anyone help me? Thank you!
Best regards,
Weihan
Re: problem launching modelsim with vivado 2013.4
The above error message gives information that user has not specified the simulator which should be used for compiling the libraries.
Since the requirement is Mo​delsim simulator you need to add the simulator name (modelsim) with compile_simlib command. You can use the below TCL command
compile_simlib –simulator modelsim
To know more about the compiling libraries in Vivado 2013.2 I request you to go through page number 110-111 in the following user guide (UG900):
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_2/ug900-vivado-logic-simulation.pdf
You can also type compile_simlib –help in TCL console which will give you more information about this command.​
Thanks,Vijay
Thank you for your reply!
I tried to type "compile_simlib –simulator modelsim" command, but it is still the same problem. In the previous TCL command, I used :
I think the first part is "simulator modelsim". Is that right? But then I do not know how to deal with the problem
I think your design contains both VHDL and Verilog file. The VHDL files would be present in few cores and Modelsim PE Student Edition would support a single HDL simulation (Verilog or VHDL) but not mixed.
http://www.mentor.com/company/higher_ed/modelsim-student-edition.
So, need not worry, Synthesize your code in Vivado, Open Synthesized design and Click on Simulate > Post-Synthesis Functional Simulation. Synthesis would absorb the mixed HDL issue and the generated post-synthesis sim model would be in single HDL OR use Vivado Simulator :)
Debraj
Thank you for your reply.
I tried your method: Synthesis first and then "Run Post Synthesis Functional Simulation" and the previous problem is solved.
However, there is a new problem:
Fatal: Attempting to load -nodebug design unit.
#  Nodebug designs are not supported.
What is this means? Thank you for your help.
Weihan
Refer to the following group discussion.
https://groups.google.com/forum/#!topic/modelsim-pe-student-edition/yCnMFfptcR4
It looks PE student edition has no support for encrypted models.
You need to either upgrade Modelsim or use Vivado simulator.
A quick attempt would be to remove -nodebug from vopt in your script. Suggestion would be to seek help from Mentor forums about limitations of Modelsim PE student version.
Debraj
