Observer bondylep
processor reset module produce to add_1 must be in the range error
Hi, I design a bd with zynq 7000, i found that once the processor reset module is instantiated, the reset output port will first not reset, then reset, when reset after one cycle, then will error show axi utils add_1 must be in the range, becase this is encrypted code ,i can't figure out why will happen, but i saw the waveform ,the m_01 axi bus valid single have X.
what can I do ,i want use the processor reset module, but can not simulate.
How can i debug with the encrypted module. is the axi interconnect should be reset first,otherwise will error.
Re: processor reset module produce to add_1 must be in the range error
The error message is coming from the assertion in AXI SRL FIFO (encrypted) used within the IP core.
This kind of failure is typically seen when master and slave AXI are not initialized. e.g. when the slave TVALID and TDATA are in an 'U' or 'X' state.
The unknown or undefined state applied to the core cause the assertions in the AXI SRL FIFO to be triggered, which terminates the simulation.
You need to firstly examine the testbench (or the AXI bus drivers) and ensure they're all initialized.
For instance,
  -- Data slave channel signals
  signal s_axis_data_tvalid              : std_logic := '0';  -- payload is valid
  signal s_axis_data_tready              : std_logic := '1';  -- slave is ready
  signal s_axis_data_tdata               : std_logic_vector(15 downto 0) := (others => '0');  -- data payload
  -- Data master channel signals
  signal m_axis_data_tvalid              : std_logic := '0';  -- payload is valid
  signal m_axis_data_tdata               : std_logic_vector(23 downto 0) := (others => '0');  -- data payload
Hi @bondylep,
Are you facing the below error?
Failure: ERROR:add_1 must be in range [-1,DEPTH-1]
Can you please check if the following posts helps:
https://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-simulation-error-2016-2-Failure-ERROR-add-1-must-be-in/td-p/726240
https://forums.xilinx.com/t5/Simulation-and-Verification/vivado-2015-1-simulation-error-Failure-ERROR-add-1-must-be-in/td-p/600653
Thanks & Regards,
Sravanthi B
Observer bondylep
I have read all the related post, and I  run the base zynq project, it is ok, i think it is not the reset module problem, maybe it is my IP problem, but i forced all the axi related x signal, it is still error. I have no other choice.
Observer bondylep
i worried about my IP, i used the VIP to drive my IP, i force the rst to low once simulation start, then the error disappear,  but the base zynq example project is the same reset module ,it is ok, the only difference is that, the axi sinal is U in good example project ,but in my proect it is X, so i worried about my IP, i can not know the root cause。
For instance,
Observer bondylep
why the example project is also U, it is ok, can you help to debug my project? if it is ok ,i will attach it
Observer bondylep
can you tell me which module will instaniate the axi_utils, because my project is so big, all module interface used axi interface, i can not locate which moduel cause the error.
which axi cause the error, axi or axis?
Observer bondylep
I finally use exclusive methord to loace the error is in the FFT IP,  i guess that the error trigger condition maybe wrong, it is the s_axis_valid should not be X, but in my Zynq system simulation,  the process rst module will not reset when simulation start up, so all singnal will X include the s_axis_valid.
Suggestion: the IP code could be encypted, but why the path also encrypted, this is not user friendly,I take about one week to locate the module which trigger the error.
