pulse generation according to given databits
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.NUMERIC_STD.ALL;
entity two_ghz is
Port ( clk : in STD_LOGIC;
rst : in STD_LOGIC;
--sclk :inout std_logic;
sdio : out STD_LOGIC;
sen : out STD_LOGIC);
end two_ghz ;
architecture Behavioral of two_ghz is
signal count_data : std_logic_vector(4 downto 0) := (others => '0');
signal count : INTEGER range 0 to 31 := 0;
signal data : std_logic_vector(31 downto 0) := (others => '0');
signal terminate_en : std_logic := '0';
signal en_count : std_logic := '0';
--signal sck : std_logic;
begin
process(clk)
begin
if rst = '1' then
sdio <= '0';
sen <= '0';
--sclk <= '0';
elsif rising_edge(clk) then
if count < 32 then
sdio <= data(31-count);
--sclk<='1' and sclk<='0';
--sclk<=not sclk;
terminate_en <= '0';--newly added
end if;
--sclk<='1' ;
if count = 31 then
terminate_en <= '1';
sen <='0';
else
sen <='1';
end if;
--sclk<='0';
end if;
end process;
process(clk,rst,terminate_en)
begin
if rst ='1' then
count_data <= (others => '0');
en_count <= '0';
if terminate_en = '1' then
count_data <= count_data + 1;
else
count_data <= count_data;
end if;
en_count <= '1';
end if;
end process;
process(clk,rst,en_count,terminate_en)
begin
if rst ='1' or terminate_en = '1' then
count <= 0;
en_count <= '1';
if en_count = '1' then
count <= count + 1;
else
count <= count;
end if;
end if;
end process;
data <= "00000000000000000000000000000000" when count_data = "00000" else
"00000000000000000000000000000010" when count_data = "00001" else
"00000000000000000000000000000001" when count_data = "00010" else
"00000000000000000001011000101000" when count_data = "00011" else
"00000000000000000110000010100000" when count_data = "00100" else
"00000000000000001110000010010000" when count_data = "00101" else
"00000000000000000010100000011000" when count_data = "00110" else
"00000000000000000000000000000000" when count_data = "00111" else
"00000000000000110000001111001010" when count_data = "01000" else
"00000000000000000000000101001101" when count_data = "01001" else
"00000000110000011011111011111111" when count_data = "01010" else
"00000000000000000011111111111111" when count_data = "01011" else
"00000000000000000010000001000110" when count_data = "01100" else
"00000000000001111100000001100001" when count_data = "01101" else
"00000000000000000000000000000000" when count_data = "01110" else
"00000000000000000000000010000001" when count_data = "01111" else
"00000000000000000000000000101000" when count_data = "10000" else
"00000000000000000000000000000000";
end Behavioral;
pulses has to be generate when the data varies ,the pulses need to be generate even if 0 and 1  bit is in data
Re: pulse generation according to given databits
Hi @anuanusha ,
I see the below output for the above mentioned code. Can you please elaborate more on the issue you are facing.
Thanks & Regards,
Sravanthi B
tq mam...for u r responce mam...
in the above output ..there is some data is there...in that data we have 32 bits .....
i want to another ouput like...."for that data i want to generate the pulses ".in the given data 1's and 0's are there...if the data is either 0 0r 1 i want to display the pulse for every bit....please support me to generate like that...
Hi @anuanusha ,
If you click on the arrow of data bus present in the waveform window as shown in the below snippet, you can be able to see the pulse waves for the individual bits as shown in the below snippet
tq mam...
but i want to serial form mam...in that ouput it can seens like parallelly  only.....i want to serial out put like.... given below page mam
Hi @anuanusha ,
If I am not wrong you are willing to see the data just like the SCK signal which is present in the shared spi.docx file. But data is a bus which is a group of bits but not a single bit similar to SDI signal present in the shared spi.docx file.
yes mam...data is a group of bits mam...but i want to anather ouput like sck...is it possible to get like that mam?
You need to write code to implement a parallel to serial shift register.  Load the register once every 32 SCLK cycles with your DATA signal.  On every SCLK cycle, shift out one bit.
tq sir..
i will try to get the output like sclk
