12-04-2015 03:37 AM
I am using vivado 2015.1 and questasim SE 64 10.0c.
When I make a change in testbench and recompile it in xil_defaultlib, waveform does not reflect change unless I close questasim and restart simulation.
I was using this feature till yesterday. But today made a new project and facing this issue.
12-07-2015 09:17 PM
@nagabhar : ofcourse I am restarting sim.
I made another project and same thing was happening to it. Then I was archiving to send it to you. After archiving the project, my problem solved magically. Incremental synthesis startrted working. May be it is vivado's bug.
12-04-2015 09:38 AM
12-06-2015 09:32 AM
HI @a4speaker
Do you mean to say , you are facing this issue only for one project?
can you please archive your project and attach it here ( go to FIle-> Archive project)
Note: Make sure that "include configuration settings" is checked
12-06-2015 10:33 PM
Hi @a4speaker
restart will restart a simulation, with any recompiled code brought in.
If you recompile a library, you will have to recompile all of the files that use that library.
Can you please try using the supported version of Questasim with Vivado 2015.1 i.e Questasim 10.3d or later?
12-07-2015 04:41 AM
12-07-2015 07:49 PM
Hi @a4speaker
Was it working with same tool versions of Vivado & Questa? If yes, this issue could be intermittent.
Try and see with other machines (if you have) to rule out machine specific issues.
12-07-2015 09:06 PM
HI @a4speaker
If the issue persists even with supported version of Questa (10.3d),
Can you please attach test project archive here so that we can check if it happenning .
Note:After Recompiling the testbench/ HDL files. You have to Click on restart button and then run the simulation.
12-07-2015 09:14 PM
Hi @a4speaker
To add, Vivado & Questa are two separate entities and the changes done in Vivado side will not take effect if you dont compile, elaborate and simulate from Questa side.
12-07-2015 09:17 PM
