questasim10.6c + vivado2017.4 for PG210
vlog compile is ok for xxv_ethernet_v2_3_vl_rfs.v. howver,vsim is failed.
usa:/test4567/sim% vlog /test789/vcu118_ip/vcu118_ip.srcs/sources_1/ip/xxv_ethernet_0/hdl/xxv_ethernet_v2_3_vl_rfs.v
QuestaSim-64 vlog 10.6c Compiler 2017.07 Jul 25 2017
Start time: 16:39:43 on May 01,2018
Top level modules:
End time: 16:39:50 on May 01,2018, Elapsed time: 0:00:07
Errors: 0, Warnings: 0
# vsim -c -printsimstats -initreport initreg.log "+ca53_tarmac_enable" -do "run -all" sim_top glbl -l vsim.log
# Start time: 16:45:52 on May 01,2018
# ** Note: (vsim-3812) Design is being optimized...
# ** Note: (vsim-3865) Due to PLI being present, full design access is being specified.
# ** Warning: (vopt-29) Unable to get status of file "/test4567/sim/work/_info".
# Input/output error. (errno = EIO)
# ** Error: /test789/vcu118_ip/vcu118_ip.srcs/sources_1/ip/xxv_ethernet_0/hdl/xxv_ethernet_v2_3_vl_rfs.v(73): in protected region
Re: questasim10.6c + vivado2017.4 for PG210
Hi @m006,
Are you trying to simulate the example design of the IP in questa 10.6c?
Have you compiled the simulation libraries successfully using the compile_simlib command?
https://www.xilinx.com/support/answers/64083.html
Are you running standalone simulation in questa? Can you please try generating the scripts using the below command from Vivado and use these scripts to run simulation, check if it helps for standalone simulation.
export_simulation -of_objects [get_files ip_name.xci] -lib_map_path "<path_to_compiled_lib>" -directory "ip_test" -simulator questa
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
Yes, questa 10.6c can compile the simulation libraries successfully using the compile_simlib command
** Warning: (vlog-159) Mode option -64 is not supported in this context and will be ignored.
QuestaSim-64 vlog 10.6c Compiler 2017.07 Jul 26 2017
Start time: 10:14:00 on Apr 28,2018
vlog -64 "+incdir+C:\Users\sina\AppData\Roaming\Xilinx\Vivado\.cxl.ip/incl" -work xxv_ethernet_v2_3_1 -f d:\xilinx_lib2017.4/xxv_ethernet_v2_3_1/.cxl.verilog.xxv_ethernet_v2_3_1.xxv_ethernet_v2_3_1.nt64.cmf
Top level modules:
End time: 10:14:04 on Apr 28,2018, Elapsed time: 0:00:04
Errors: 0, Warnings: 1
Simulated the 10G/25G Ethernet Subsystem example design without any problems:
# do {xxv_ethernet_0_exdes_tb_simulate.do}
# vsim -lib xil_defaultlib xxv_ethernet_0_exdes_tb_opt
# Start time: 12:18:09 on May 01,2018
# Loading work.xxv_ethernet_0_exdes_tb(fast)
# Loading work.xxv_ethernet_0_exdes(fast)
# Loading work.glbl(fast)
# 1
# 1
# .main_pane.wave.interior.cs.body.pw.wf
# .main_pane.structure.interior.cs.body.struct
# .main_pane.objects.interior.cs.body.tree
# INFO : SYS_RESET RELEASED TO CORE
# INFO : WAITING FOR THE GT LOCK..........
# End time: 12:30:20 on May 01,2018, Elapsed time: 0:12:11
# Errors: 0, Warnings: 0
can you provide a full simulation script for questasim10.6c?
Hi @m006,
I ran the simulation of the example design for the IP in Vivado 2017.4 and ModelSim 10.6c
Attached is the simulation script generated by the tools using the export_simulation comand
You can get details of the command using export_simulation -help in the tcl console.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
@amaccre
Your test is using ModelSim but the problem is on QuestaSim. I'm running into this identical issue when simulating the fifo_generator_v13_2_rfs.v from Vivado 2017.3 on QuestaSim10.5c (after running the vsim command):
** Error: ../SourceCode/IP_Vivado_2017.3/CCFIFO16x32/hdl/fifo_generator_v13_2_rfs.v(64): in protected region
This error occurs with newly generated 2017.3 simulation libraries for that exact QuestaSim10.5c
Luis
Hi @lbenites,
QuestaSim 10.5c will not work, you need a minimum of version 10.6b when using Vivado 2017.3 or 2017.4.
This is documented in UG973
You will also have to compile the simualtion libraries for each matched pair of Vivado version / Questa version otherwise the ip versions may not match and you could run into trouble e.g for 2017.3 compile the libraries and also for 2017.4 compile the libraries.
I ran the simulation in QuestaSim 10.6b and it worked as expected.
Best Regards
Aidan
Thanks for the clarification @amaccre, 10.5c had been working fine for all previous version of Vivado libraries I had used for simulation. Maybe in the future Vivado should issue a warning when it's asked to generate libraries for an unsupported version of the simulator.
Apologies for hijacking the thread. I though the problem was similar enough to add to the conversation.
Thanks again,
Luis
can you tell me how to download questasim10.6c or modelsim 10.6c, or share install file with me? thanks.
