guiboo
"ERROR: [Common 17-161] Invalid option value '' specified for 'object'." while trying to start a Behavioral Simulation
Hello everyone, i'm reaching a problem with a behavioral simulation. I tried to change the project directory path and the simulation source file name according to some topics I saw about this issue but it didn't work.
The problem seems to come from a global include which is surprising while my only one include is a timescale.
Here is the complete error message :
INFO: [USF-XSim-27] Simulation object is 'sim_1'
INFO: [USF-XSim-37] Inspecting design source files for 'testbench' in fileset 'sim_1'...
INFO: [USF-XSim-66] Exported 'C:/Vivado/project_1_Impl/project_1.srcs/sim_1/new/testbench.sv'
INFO: [USF-XSim-97] Finding global include files...
while executing
"get_property "IS_GLOBAL_INCLUDE" [lindex [get_files -quiet $file] 0]"
("foreach" body line 2)
invoked from within
"foreach file $vh_files {
if { ![get_property "IS_GLOBAL_INCLUDE" [lindex [get_files -quiet $file] 0]] } {
continue
set fil..."
("foreach" body line 3)
invoked from within
"foreach fs_obj $filesets {
set vh_files [get_files -quiet -of_objects [get_filesets $fs_obj] -filter $filter]
i..."
(procedure "usf_get_global_include_files" line 20)
invoked from within
"usf_get_global_include_files incl_file_paths incl_files"
(procedure "usf_get_files_for_compilation_behav_sim" line 20)
invoked from within
"usf_get_files_for_compilation_behav_sim $global_files_str"
(procedure "::tclapp::xilinx::xsim::usf_get_files_for_compilation" line 12)
invoked from within
"::tclapp::xilinx::xsim::usf_get_files_for_compilation global_files_str"
(procedure "usf_xsim_setup_simulation" line 35)
invoked from within
(procedure "tclapp::xilinx::xsim::setup" line 15)
invoked from within
"tclapp::xilinx::xsim::setup { -simset sim_1 -mode behavioral -run_dir C:/Vivado/project_1_Impl/project_1.sim/sim_1/behav -int_os_type 64 -int_debug_mo..."
Would you have any advice for this issue please ?
I'm still a newbie in this field of knowledge, please have mercy !
