dblogicdesign
readmemh with concatenated string for file name
I'm trying to use a string constant with the $readmemh statement in my system verilog testbench.  The Vivado (2018.2) simulator generates warnings that it cannot find the file.  If I explicitly define the file location it works.
Does not work:
const string saveDir = "C:/work/test_cases/test0";
$readmemh({saveDir,"/file.txt"}, file_data)
Also does not work:
$readmemh(sformatf({saveDir,"/file.txt"}), file_data)
Works:
$readmemh("C:/work/test_cases/test0/file.txt", file_data)
I've used $display to verify the concatenation is in fact producing the required directory/file string.  I have many $readmemh statements in my test bench and it would be nice to be able to quickly change the test directory by simply changing the value of 'saveDir'.  Is this a limitation in the Vivado simulator or system verilog, or am I doing something wrong?
dblogicdesign
Tried one more thing 5 minutes after posting my question and found that changing saveDir from a constant to a parameter solved the problem.
dblogicdesign
rshekhaw
Hi @dblogicdesign ,
As the issue is resolved, do you have further queries on this? If not, please close this thread by marking it as accepted solution.
Raj
