Observer moshiko
readmemh with string/parameter filename
I would like to use readmemh within task/module where the filename comes from input string (to task) or as parameter (to module).
Both options pass xvlog and xelab. However, when using Vivado (2017.1) for simulation it gives me "fatal error" when using either of these options.  Only literal string of the filename works out.
Is there any way to pass filename as argument so that coding around memory initialization can be grouped into a task/module and only the filename is given as input/parameter?
-Moshe
Scholar watari
Re: readmemh with string/parameter filename
Hi @moshiko
Could you show me more detail information or upload log file ?
Observer moshiko
Attached an example of readmemh receiving filename as parameter + Error received from Vivado simulator when stepping over the readmemh call.
reg [DDRDATAW-1:0] ztlmem [9999:0];
module ztl_mem #(parameter FILENAME = "aaa.txt") (input en);
    integer ztladdr, i;
    always @(en)
         if (en) begin
             $readmemh(FILENAME, ztlmem, 0);
         end
endmodule
FATAL_ERROR: Vivado Simulator kernel has discovered an exceptional condition from which it cannot recover. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
Observer moshiko
Has anyone faced similar problem and maybe managed to find a workaround ?
-Moshe
Scholar watari
Hi @moshiko
Would you use the following code ?
    integer ztladdr, i;
    initial $readmemh(FILENAME, ztlmem, 0);
endmodule
Best regards,
Observer moshiko
I used the code below and still get the same fatal error.  (same code works if FILENAME is replaced by the literal "file.txt")
Besides, it would be better if I can load different files as simulation progresses, not only at initial time.
-Moshe
reg [DDRDATAW-1:0] ztlmem [99999:0];
module ztlload #(parameter FILENAME);
endmodule
ztlload #(.FILENAME("file.txt")) ztlload_i ();
