muzaffer
reference arguments are broken in simulation?
I am trying to get the following test to run:
// test for ref parameters
module test;
int a;
initial
begin
#10 a = 10;
#10 a = 20;
#10 a = 30;
#10 $finish;
end
task pass_by_val(int i);
forever
@i $display("pass_by_val: I is %0d",i);
endtask
task pass_by_ref(ref int i);
forever
@i $display("pass_by_ref: I is %0d",i);
endtask
initial
pass_by_val(a);
initial
pass_by_ref(a);
endmodule
 If I am not missing anything this should print
pass_by_ref is 10
pass_by_ref is 20 ...
But I get nothing when I run this test. Does Vivado simulator support reference arguments properly?
muzaffer
this is a very much simplified case. My main problem was trying to pass a clock as a ref argument. A task with a @(posedge clk) where clk is a ref argument doesn't see any events. I think the problem is still that ref arguments don't work. In your example every time the variable changes, you call the task again so the event is detected outside the task. If the ref worked properly the event could be observed inside the task too.
dprasad
First you need to do slight modification in your example i.e change the definition of task 'pass_by_ref' as automatic becuase task/function having ref port can't be static so change to
task automatic pass_by_ref ...
Coming on Vivado Simulator side, it's bug which need to be fixed. The issue is not with ref port, it's because of forever block inside that. If you want, you can do slight modification like
____________________
module test;
int a;
initial
begin
#10 a = 10;
#10 a = 20;
#10 a = 30;
#10 $finish;
end
forever
endtask
task automatic pass_by_ref(ref int i);
//forever
//@i
endtask
initial
pass_by_val(a);
initial
forever @a pass_by_ref(a);
endmodule
_______________
And with, you should see the expected o/p.
--dhiRAj
muzaffer
muzaffer
this has been accepted as a bug in Vivado simulator, Modelsim does the right thing, xsim doesn't.
