regarding xilinx
hi download xilinx software last month.I do whole programming without any error but at the end i did not get my waveform how i can fix that problem.
Advisor
Advisor
Hi and welcome,
  You may start by describing your case in more detail, sharing code, error messages and any steps to reproduce your problem. Your description is as vague as it comes.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
@karm
@patocarrhas an excellent point.
However since you are talking about a waveform I suppose this is a simulation issue.
Check this post out. A fellow wrote a 4b adder and I gave him a testbench to try.
https://forums.xilinx.com/t5/Simulation-and-Verification/Simulation-Error-NewBie-Misstakes/m-p/1159552#M30480
Start small. There's also simulation tutorials to get you started with Vivado.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug937-vivado-design-suite-simulation-tutorial.pdf
Have fun,
Jerry
I am unable to open my vivado2020.1 when i am trying to open it is showing error when launching C:\Xilinx\Vivado.bat': Launcher time out. And also not give any wave form at the end
Ok, so if I understand it,
you are unable to launch vivado , or is this an unable to install vivado ?
First up questions,
have you had other version of vivado running on this machine,
how are you launching Vivado , are you using a DOS prompt ?
if its a DOS prompt, is it the xilinx one , which has the environment set up , or the standard windows one ?
What is the OS your using ?
Advisor
Advisor
