remove all force signal values in vivado simulator
Hello in my siimulation I'm running tcl commands to force signals values in runtime for save time and efford during first steps of simulating a design but when I want to restart the simulation to change the signal behaviour the previous force signal values remains in simulation and this can cause problems in my new simulation.
The question is, how can I declare an tcl command for remove all force signal values in a simulation?.
I know is possible to do it with one signal but do it for every signal changed in a simulation could be a little bit tedious and generate some mistakes.
regards.
Hello @jmartinez,
You can use command below command -
remove_forces -all
Ashish
Hello @jmartinez,
remove_forces -all
Ashish
Hi @jmartinez
Additionally, -help will give you all details related to the usage of the command.
For example remove_forces -help
Thanks,Vijay
thanks @vijayak and @ashishd, is was exactly what I was looking for.
regards, julian.
