Visitor gopal.maste
saving the isim binary data in the wave form to a text file.
hello all,
i am working on a design where the simulation data has to be saved as in a .TXT format for verifying it with another set of data , i have surfed many options but still not able to make out the correct way to it.
an early response will be appreciated.
thanks,
gopal.
Re: saving the isim binary data in the wave form to a text file.
Hello ...
One option that might work for you is the Value Change Dump (VCD) file export. This is an ascii format file that represents the data from the simulation run. This option is decribed in the ISim User's Guide as can be found here:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/plugin_ism.pdf
One place the VCD format itself is described here:
http://en.wikipedia.org/wiki/Value_change_dump
However, what I would recommend is recording the data at critical points in the simulaton that you wish to save to a file yourself via testbench code, and then use that as a golden simulation file for comparison during later runs. In many cases, with asynchronous FIFOs and other asynchornous circuits, the data will be output on a different clock cycle than a previous simulation, but still be correct, so a direct simulation wave comparison would not be accurate.
OK, I hope this
Scott
Teacher muzaffer
What about adding $fdisplay statements to your simulation to capture the data in exactly the way you want (including when to sample it, exact output format etc) ?
