send_tready() hangs using AXI-Stream VIP
I use AXI4-Stream VIP for simulation. I want to generate NO backpressure, so I want to assert the tready all the time at slave VIP.
Here is a snippet of my simulation:
axi4stream_ready_gen    ready_gen;
axis_vip_slave_slv_t   s_axis_agent;
s_axis_agent = new("s_axis_agent", sim_top.DUT_tb.inst_axis_vip_x0y4_slv.inst.IF);
s_axis_agent.start_slave();
// Generate NO backpressure
ready_gen = s_axis_agent.driver.create_ready("ready_gen00");
ready_gen.set_ready_policy(XIL_AXI4STREAM_READY_GEN_NO_BACKPRESSURE);
s_axis_agent.driver.send_tready(ready_gen);
The last statement: send_tready() doesn't return at all. Why?
I use:
  • Win 10
  • Vivado 2017.4
Re: send_tready() hangs using AXI-Stream VIP
Finally I found that the VIP was in reset state.
(I still cannot understand why it cannot set the tready policy in reset state...)
