set_property display_limit not allowing for large objects to be displayed (Vivado 2018.1)
I'm wanting to observe some large testbench objects in the waveform viewer. Specifically an object like tx_views:
localparam integer    TESTCASE_VIEWS = 2;
localparam bit [12:0] VD_BUFFER_SIZE = 15'd3456;
bit [127:0] tx_views [TESTCASE_VIEWS-1:0][VD_BUFFER_SIZE-1:0];
So the size of the object is 2 * 3456 * 128 = 884,736 bits. So I'll set the display_limit to 1,000,000 just to allow for some overhead or in case I make a small change to the VD_BUFFER_SIZE later. And just to be sure, I read back the property to check my syntax in increasing the value was done correctly:
set_property display_limit 1000000 [current_wave_config]
get_property display_limit [current_wave_config]
1000000
However, even after all this was done, I can't see to add the large object to my display window. I applied this changes after the simulation had been initialized and run for 1 us.
I hypothesized that I might need to restart the simulation for the new display_limit to take effect, but when I do that the display_limit is reset to the default:
65536
So I'm left wondering, how do I get the display_limit to properly allow me to add large objects to the waveform viewer, or have I had some limit so the command fails without an error message?
Further, once I can get it working properly, how can I make this property persistent so I don't need to reset it every time I restart my simulation?
P.S. I've also tried making the array completely packed, but that didn't help either.
When I launched simulation and firstly tried to add the vector to wave, I received this warning.
add_wave {{/ODMB_vfp_tb/tx_views}}
WARNING: [Wavedata 42-489] Can't add object "/ODMB_vfp_tb/tx_views" to the wave window because it has 884736 bits, which exceeds the display limit of 65536 bits. To change the display limit, use the command "set_property display_limit <new limit> [current_wave_config]".
After setting a new limit to the wave config, I was able to add it to wave but no value is shown.
You need to quit simulation and set the following additional properties to have it correctly logged and displayed.
set_property xsim.array_display_limit 1000000 [current_project]
set_property xsim.trace_limit 1000000 [current_project]
Then launch simulation and set display_limit.
You can then add it to wave and view the value in waveform.
@barrygmoss,
Did you try changing the display_limit and then *re-runing* the simulation (don't restart)?
Call simu through a TCL script where in the display_limit will be changed.
FPGA enthusiast!
All PMs will be ignored
Thanks for the suggestion. Hitting the relaunch button instead of restart does indeed preserve the value of the property.
However, the set_property still doesn't seem to allow me to add large objects (as I mentioned in my original post) to the waveform.
Are you able to see the vector in Objects window?
Did you receive any message when you tried to add it to wave?
The vector is visible in the Object window. There are no messages in the Tcl Console or the Messages window when I attempt to add it to the wave by dragging it to the waveform window.
If you see vector value truncated, try setting the below property.
set_property array_display_limit <bits> [current_sim]
I gave that a try, but sadly, it's still failing. The vector isn't truncated, it just doesn't show up in the simulation window at all when I drag it over (where as much shorter vectors will appear).
Do you see all bits shown up in the Objects window?
If possible, please attach the project archive for a look.
Here's a screen shot of some of the larger items in my objects window. It looks correct:
I'm happy to provide a design archive. Is there some way I can do that without posting it publicly?
Barry
Please message me with your email address and I'll send you an EzMove (a file transfer application) link to upload the design.
Thanks! I've got it going now.
