signal Connection in testbench
In my testbench, there are two modules.
t1 uut1 (.a(a), .b(b), .c(c));
t2 uut2 (.a1(a), .b1(b), c1(c1));
c1 is the input for t2, and signal a, b is output signals. a, b is input signals for t1, c is output signal.
what type of signals  should I define the signals in order to connect the two modules?
Should I define a,b as wire?
Re: signal Connection in testbench
If a and b are not ports, you need to declare them as wire.
Do check the document: http://www.xilinx.com/support/documentation/application_notes/xapp199.pdf for writing effective testbenches.
Debraj
