signal delay problem in post route simulation
hello
when i try to simulate my design in poste route mode simulation in ISIM i encounter some problems,
the signal delays are not shown in the simulation
does any one knows how should i fix it?
thanks saber
Teacher muzaffer
Re: signal delay problem in post route simulation
check to make sure you generated the SDF file correctly and it is being annotated on the design properly.
thanks for your answer and your time, i can see the generated file .sdf , but i dont it is generate correctely or not how can i add this file to ISIM
whats ur mean about annotated correctely?
when i simulate i see these erors how can i fix it??
ERROR: Can not find hierarchical name Maddsub_o1_mux0007_Madd_92_rt in the current scope. ERROR: SetupHold can not be annotated for Maddsub_o1_mux0007_Madd_92_rt. ERROR: Can not find hierarchical name Maddsub_o1_mux0007_Madd_92_rt in the current scope. ERROR: SetupHold can not be annotated for Maddsub_o1_mux0007_Madd_92_rt. ERROR: Can not find hierarchical name Maddsub_o1_mux0007_Madd_92_rt in the current scope. ERROR: SetupHold can not be annotated for Maddsub_o1_mux0007_Madd_92_rt. ERROR: Can not find hierarchical name Maddsub_o1_mux0007_Madd_92_rt in the current scope. ERROR: SetupHold can not be annotated for Maddsub_o1_mux0007_Madd_92_rt. ERROR: Can not find hierarchical name center1_5 in the current scope. ERmemvalue1_5.
WARNING: ISim could not properly annotate the SDF timing delay information.
Teacher muzaffer
It seems that you have an SDF file but it's not being annotated properly. You need to figure out how $sdf_annotate is being called. You might need to add the proper --sdfroot to your compilation script. The errors you see suggest that annotation is not starting at the right point in hierarchy. Find out where Maddsub_o1_mux0007_Madd_92_rt is and add -sdfroot to that.
Whatversionoftools are you using?
In case of using VIvado 2012.X please refer http://www.xilinx.com/support/answers/54930.html
