simulate vivado design from questasim gui
I have a vivado design that uses multiple xilinx cores, including a clock wizard generated core, fifos and memory, and a tristate ethernet core.  I would like to launch a simulation from Questasim without starting vivado.  What files need to be referenced for vcom and vlog to get a good simulation compile from questasim.
Please let me know for the memories, the clock and the ethernet core.
Fred Skalka
Tags (2)
IP cores should have a <corename>_sim_netlist.v/vhdl file in their folders. These are the only files you need to compile, assuming all you want is an RTL simulation.
But be wary. I have a 10G mac core, and the simulation netlist is a 40mb text file. Its probably going to be VERY slow to simulate. Usuaully more productive just to model the interface.
