fpgalearner
Voyager
Voyager
simulating Aurora 8b/10b for artix 7
I am simulating example design of aurora 8b/10b (artix7) for about 1ms in vivado
https://www.xilinx.com/support/documentation/ip_documentation/aurora_8b10b/v11_0/pg046-aurora-8b10b.pdf
and it took about half an hour but still I didn't see lane up and channel up signal.
How long does it need to simualte? do I need to set some additional parameters for this purpose?
roym
The recipe in http://www.xilinx.com/support/answers/72227.htm should work for you if you can adapt it to the aurora hierarchy.  Put the speedup parameter at the GT into the wave window to make sure it is getting set properly.
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
fpgalearner
Voyager
Voyager
@roym
from that link only this part I could use in vivado example design simulation for aurora:
initial
begin
force example_design_1_i.aurora_module_i.aurora_xc7a_8b10b_GTP_2_5g_100m_2l_i.inst.gt_wrapper_i.aurora_xc7a_8b10b_GTP_2_5g_100m_2l_multi_gt_i.gt0_aurora_xc7a_8b10b_GTP_2_5g_100m_2l_i.gtpe2_i.DRPWE = 1'h0;
force example_design_1_i.aurora_module_i.aurora_xc7a_8b10b_GTP_2_5g_100m_2l_i.inst.gt_wrapper_i.aurora_xc7a_8b10b_GTP_2_5g_100m_2l_multi_gt_i.gt1_aurora_xc7a_8b10b_GTP_2_5g_100m_2l_i.gtpe2_i.DRPWE = 1'h0;
force example_design_2_i.aurora_module_i.aurora_xc7a_8b10b_GTP_2_5g_100m_2l_i.inst.gt_wrapper_i.aurora_xc7a_8b10b_GTP_2_5g_100m_2l_multi_gt_i.gt0_aurora_xc7a_8b10b_GTP_2_5g_100m_2l_i.gtpe2_i.DRPWE = 1'h0;
force example_design_2_i.aurora_module_i.aurora_xc7a_8b10b_GTP_2_5g_100m_2l_i.inst.gt_wrapper_i.aurora_xc7a_8b10b_GTP_2_5g_100m_2l_multi_gt_i.gt1_aurora_xc7a_8b10b_GTP_2_5g_100m_2l_i.gtpe2_i.DRPWE = 1'h0;
end
Simulation speed up in page 81 of this document:
but seems no impact in simulation time.
Furthermore I would like to know if this setting also works in VCS simulation?
