Anonymous
Not applicable
simulating in ISE
I am trying to simulate a hdl file in ISE using testbench waveform. Its a simple adder.
When I try to run the behavioral simulation, nothing changes.
I've attached the screen shot.
inputs a and b are 8 and 1, I am expecting the sum to change after I run the simulation. But nothing changes.
Anonymous
Not applicable
Re: simulating in ISE
Project clean up didn't make much difference. I just started fresh with new project and all seems to work now.
double click on the xc2c*.** and input the valid info
look like it is pointing to the modelsim simulator.
you will change it to ise simulator by double click on the xc2c*.**
Anonymous
Not applicable
Boris,
I made the changes, here's the screen shot again
I have modelsim XE, the ISE does not support XE. I will try downloading SE.
Anonymous
Not applicable
Tried both modelsim SE and PE. Both didn't work.
Shouldn't ISE support modelsim XE?
The problem here is that you are attempting to compile the HDL libraries while using either ISE Simulator ModelSim XE.  You need not compile the HDL libraries in either of these simulators as the libraries have already been pre-compiled for you.  All you need to do at this point is double-click on "Simulate Behavioral Model" while highlighting your testbench.
Hope this helps.
Eddie
Anonymous
Not applicable
edv,
I did try "simulate behavioral model", and got the following errors-
ERROR:HDLParsers:3562 - pepExtractor.prj line 1  Expecting 'vhdl' or 'verilog' keyword,  found 'work'.
ERROR:HDLParsers:3596 - Project file 'C:/Modeltech_xe_starter/My projects//my_adder_tbw_bencher.prj' does not exist.
ERROR: Update TBW failed
In the sources window should I select "my_adder_tbw" or "UTT-my_adder-arc1"?
Message Edited by hithesh on 03-05-2009 09:52 AM
A few things,
1) Please refrain from keeping ISE projects in paths with spaces.  ISE does not support spaces in the project directory.
2) Run "Clean Up Project Files" in order to regenerate the .prj file.  It is possible that the file has been corrupted.
Hope this helps.
Eddie
Anonymous
Not applicable
