simulation crashes after upgrade to 2017.1
Visitor jcz
installed 2017.1
loaded a 2016.4 project
saved project to new location
restarted 2017.1
ran behavioral simulation
crashed with internal application error
attached vivado.tar is original 2016.4 project
attached vivado_pid14919.zip is error info generated at time of crash
I'll continue with 2016.4 until this is solved
Re: simulation crashes after upgrade to 2017.1
Hi @jcz,
Can you please share OS information.
I have Verified this project in Linux and I didn't see Fatal error.
Sunilkumar
Visitor jcz
linux mint with
jcz@florida:~$ cat /etc/upstream-release/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=14.04
DISTRIB_CODENAME=trusty
DISTRIB_DESCRIPTION="Ubuntu 14.04 LTS"
jcz@florida:~$
installed 2017.1
restarted 2017.1
Advice from my ~4yrs of experience with Vivado...
Refrain from using the latest versions of Vivado AS SOON AS THEY ARE RELEASED. They will have bugs. You will have a tough time. As a thumb rule : allow atleast 6 months of time for a new Vivado to be in the market before using it (I personally do not use Viv versions that ar enot 1 year old)!
FPGA enthusiast!
Hi @jcz,
I have simulated the 2016.4 design in 2017.1 version in Ubuntu using the steps you mentioned. I didn't see the Internal exception. Simulation ran for 1000ns and opened  the WCFG files with the signal values.
Following is the OS details:
Distributor ID: Ubuntu
Description: Ubuntu 16.04 LTS
Release: 16.04
Sunilkumar
Visitor jcz
I have the same problem with other projects also.
