arquer
strange randomization behavior
Since XSIm does no support setting a global random seed through command line/tcl for the time being I am passing a paramenter to my simulation (SEED) which I use to randomize the TB.
inside the testbench I have someting like this:
initial begin
$display("Seeting sim seed to : %d", SEED); $srandom(SEED); fork forever begin $display("urandom_range generated number: %d", $urandom_range(1,256)); $display("urandom generated number: %d", $urandom()); (...) random_access_read_data = new[$urandom_range(1, 256)]; $display("Random size: %03d", random_access_read_data.size()); startaddr = $urandom_range(32'h800, 32'hFFF - random_access_write_data.size()*4); $display("Random start address: 0x%04x", startaddr); (...) end join_none (..) end
I have two simulation to which I pass different seeds. I would expect alll the $display() calls to show different values, however I get:
Sim1:
Seeting sim seed to :              1652197961
urandom_range generated number:    208
urandom generated number:          -1192071567
Ransom size:                       147
Ransom start address:              0x0d4c
Sim2:
Seeting sim seed to :             844802871
urandom_range generated number:   158
urandom generated number:         -1444523949
Ransom size:                      147
As you can see the SEED passed are indeed different, and so are the two first generated random numbers (both with urandom_range and urandom). However the values that I actually care about, the size of the dynamic array and the start address are the same!
How can it be if those are generated using the same calls as the first three?!
I really don't know what to make of this :(
sunilku
Hi @arquer,
I am getting different results for different seed values.
Test case:
module test;
parameter p1 = 12;
parameter p2 = 14;
int random_access_read_data[];
int startaddr;
initial begin
  $srandom(p1);
  $display("urandom_range number: %d", $urandom_range(1,256));
  $display("urandom number: %d", $urandom());
  $srandom(p2);
end
endmodule
Result:
urandom_range number:        241
urandom number: 1141840264
Random size: 219
urandom_range number:         63
urandom number:  427998515
Random size: 077
Please share your design file so that I can check and update you.
Sunilkumar.
arquer
Hi @sunilku
the issue seems to appear when I have both a fork/join (as in my example) and also a @(posedge Clk) in between the random calls, please try the following:
logic Clk = 0;
always #5 Clk = !Clk;
initial begin (...) $display("Seeting sim seed to : %d", SEED); $srandom(SEED); fork forever begin $display("urandom_range generated number: %d", $urandom_range(1,256)); $display("urandom generated number: %d", $urandom()); (...)
@posege(Clk);
With this you should see how the generated values before the posedge change with the provided SEED but the ones after don't.. :(
sunilku
Hi @arquer,
Can you please share the complete test case.
Sunilkumar
arquer
I can not share the whole design... it is huge. That is why I took the time to write a minimum code which reproduces the issue...
module moduleTb#(
    parameter longint SEED       = 123456789
    timeunit 1ns;
    timeprecision 1ps;
    logic       Clk = 1'b1;
    initial begin
        logic [31:0] random_access_read_data [];
        logic [31:0] random_access_write_data [];
        int startaddr;
        $display("Setting sim seed to : %d", SEED);
        $srandom(SEED);
        fork
            forever begin
                //Comment the following line and the issue seems to go away...
                //@(posedge Clk);
                random_access_write_data = new[random_access_read_data.size()];
                $finish();
            end
        join_none
    end
endmodule
 If you run this code as with vivado 2017.2 you should see:
Sim1:
Setting sim seed to :             844802871
urandom generated number: 2850443347
Random size: 144
Random start address: 0x0d5a
Sim2:
Setting sim seed to :            1652197961
urandom generated number: 3102895729
Random size: 087
Random start address: 0x0ad9
So different numbers, all good.
However if you uncomment that @(posedge Clk) line, you will see:
Sim1:
Random size: 147
Random start address: 0x0970
Sim2:
Random size: 147
Seeds are different and generated values before the posedge are indeed different, however after that line the seed seems to be restored to some other value....
arquer
Anyone?
If someone could at least verify the issue I am seeing I will go ahead and open a support ticket. I just wanna make sure I am not doing something wrong.
sunilku
Hi @arquer,
I am not seeing any difference in the result. In both scenarios I am seeing the same results if I run simulation multiple times.
Please find the results below.
sim1:
Setting sim seed to :             123456789
urandom_range generated number:         83
urandom generated number: 2730531909
Random size: 055
Random start address: 0x0e46
sim2:
Random size: 055
If i uncomment the the line  @(posedge Clk)
sim1:
Random size: 147
sim2:
Random size: 147
Random start address: 0x0970.
Which OS and Vivado version are you using?
Sunilkumar
arquer
Hi @sunilku
the reason you are not seeing any variation in the random numbers generated is because both of your simulations have te same SEED parameter (the default one).
You can see this at the beggining of the simulation when the SEED paramenter is printed out.
You can modify the seed either by directly modifying the code or by adding an elaboration parameter to elaboration such as:
-generic_top "SEED=XXXXXXX"
You can try to assign the same seeds I assigned and hopefully you should see the exact same numbers as me.
dsheils
Hi All,
I looked into the support case for the issue in this thread. As @arquer mentioned above, you'll get the same sim results if the SEED parameter is the same. You'll need to change it for each simulation run.
Best Regards,
D
Can you please mark the appropriate post as an answer "Accept as solution" in case it helped resolve your query?
This will help other users in future looking for the same query with an accepted answer.
It will also close this thread.
arquer
Hi @dsheils,
Have you tested the provided examples with the same seeds I posted the results for?
dsheils
Just to wrap this one up, the issue above was identified as being an issue with the tools. A CR was filed to get it fixed in a future version of Vivado.
