mkoko
testbench question
when i made a simulation for my code then choose added  to wave all items in region the following error apear:
# (vish-4014) No objects found matching '/testbench1/*'.
please i want to know what is the problem ?
i used modelsim 6.5
gszakacs
Professor
Professor
Can you post a screenshot from Modelsim?
How did you try to add the signals to the wave?  From the command line?  something like:
add wave -r /testbench1/*
-- Gabor
debrajr
Is the issue already fixed? Kindly post the screenshot file for community members to check? If its resolved, post in the resolution or mark the answer which helped you the most as "Accepted Solution"
Debraj
