Visitor machineallen
unable to run testbench: Error 793
I have written a verilog HDL for Spartan 6. I can program it on device but the result is not good. So I wrote a testbench to see if logic problem. But when I executed ISim Simulator and ran Simulated Behavioral Modle. The report generated as below:
ERROR:Simulator:793 - Unable to elaborate instantiated module Memram
I have no idea and can not the searched the related result about this error.
Re: unable to run testbench: Error 793
The error message means that the simulator cannot find a module named Memram in the sources that it was given.
hi mcgett ,
The test fixture included a uart.v file and the uart.v included the Memram.v.
Do you mean the test fixture have to declare the Memram again?
It's not the verilog code, by the project file for the simulation that you are running that must include the Memram.v file along with all of the other design files.
