Newbie stchoula
unable to simulate FFT ip core v9.0 with modelsim
I have vivado 2014.1. I generated FFT core 9.0 and was able to simulate the latter with vivado.
However, i don't know what files I have to add to a modelsim project in order to simulate my design via modelsim
Any help?
Re: unable to simulate FFT ip core v9.0 with modelsim
In the simulation setting use the generate scripts option and select Modelsim as the simulator which generates an script files with all the required files and libraries.
You can use the generated script to look at the required files for simulation and use it in your standalone Modelsim project.
Satish
