eanema
unexpected results in simulation
Hi all,
I have a mind-bending question regarding weird results in simulation. I am trying to enable a clock output by setting or clearing an enable register based on the state of 5 input signals: watchdog_en_n, check_pulse_i, thisAP_out, thatAP_out & cross_check_pulse_i.  The code used to change the enable signal is:
-- clock enable signal
process(clk)
begin
    if(rising_edge(clk)) then
-- use truth table to determine the state of the clock generater enable signal case std_logic_vector'(watchdog_en_n & check_pulse_i & thisAP_out & thatAP_out & cross_check_pulse_i) is when "00000" | "00001" | "00011" => thisAP_in_en <= '1'; when others => thisAP_in_en <= '0'; end case;
end if; end process;
I wrote a test bench to test all possible input combinations. The result is shown below:
From the VHDL code, I would expect thisAP_in_en to only be '1' in three case, and every other case it would be '0'. But for some reason, thisAP_in_en is '1' when I expect it to be, but ALSO is '1' when watchdog_en_n = '0' and check_pulse = '1' and thisAP_out = '0'.
Can anyone offer any insight as to why this might be the case??! The process above is the only process that writes to the signal although it is read a couple of other places.
Thanks!
eanema
OK, so my bad.
after posting this I noticed that I was controlling cross_check_pulse and check_pulse, NOT cross_check_pulse_i and check_pulse_i
Derp.
Thanks!
eanema
Sorry, I should also have mentioned that I am using Vivado 2018.1
eanema
OK, so my bad.
Derp.
Thanks!
