sai_shashi
using sinusoids in simulation
Hi there,
I need to use sine and cosine as inputs to my DUT through test-bench. I have no clue on how to accomplish this. can anybody please guide me on this..?
Thanks in advance
hpoetzl
Voyager
Voyager
Hey @sai_shashi
Really depends on the language (C, C++, VHDL, Verilog) and tools (Vivado, HLS, GHDL, etc) you are using and at what level the simulation happens.
Best,
Herbert
-------------- Yes, I do this for fun!
sai_shashi
Thanks for the reply,
I am using SystemVerilog testbench.
I am simulating in Vivado environment.
I am simulating the design before the synthesis.
dpaul24
You can use VHDL/Verilog to code for Taylor series expansion up to 3 terms. It generates fairly accurate sine and cosine waveforms.
https://en.wikipedia.org/wiki/Taylor_series#Trigonometric_functions
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
bruce_karaffa
I prefer to read my test bench signal inputs from a text file.  This provides a lot of flexibility since it's easy to create different frequency sinusoids, add noise, etc.  Matlab is good for this, but in a pinch, you can use Excel or a Matlab clone like Scilab.
hpoetzl
Voyager
Voyager
@sai_shashi
For the test bench, something like this should suffice (untested):
const real pi = 3.14159265359;
real freq = 1e3; real offset = 0.5; real ampl = 0.3; real sine_out; always @(sampling_clock) begin sine_out = offset + (ampl * sin(2 * pi * freq * $time * 1e-12)); $write("Sine value at time=%0g is =%0g\n", $time, sine_out); end
Hope it helps,
Herbert
