uvm not working with version 1.1 in vivado 2019.2
   I tried to simulate UVM test bench which was written in version 1.1 using VIVADO 2019.2 simulator. I simulated the testbench in VCS and it is working. But it is not working with Vivado. I posted the commands which I used to generate the top level object. It is giving me an error which actually should work for UVM 1.1 I attached the test case.
exec xvlog -sv ~/Vivado/2019.2/data/system_verilog/uvm_1.2/uvm_macros.svh -L uvm -uvm_version 1.1
exec xvlog -sv ~/Vivado/2019.2/data/system_verilog/uvm_1.2/xlnx_uvm_package.sv -L uvm -uvm_version 1.1
exec xvhdl -f dut.f
exec xvlog -sv -f tb.f -L uvm -uvm_version 1.1
exec xelab top --timescale 1ns/1ps -L uvm -s top_sim -debug typical -uvm_version 1.1
ERROR: [XSIM 43-4273] File ~/Vivado/2019.2/data/system_verilog/uvm_1.2/xlnx_uvm_package.sv, line 6949. function call actuals passed more than formal args.
child process exited abnormally
Re: uvm not working with version 1.1 in vivado 2019.2
Hello Forum,
   I figured out the issue. Looks like Vivado 2019.2 doesn't support code coverage yet. In the test, I am using coverage and once I removed it the test started working.
Hello Forum,
