view array or BRAM memory contents in vivado with USB Xilinx platform cable III
On the hardware, is there a technique to view the contents of arrays or BRAM with the USB Xilinx platform cable III?
Frank
Voyager
Voyager
Hey @travellingwave,
I know BRAM is not SDRAM.
Good! :)
Would the simplest technique be to copy from BRAM to SDRAM with AXI BRAM controller ...
The AXI BRAM controller does not copy anything from BRAM to SDRAM, it provides a register interface to a BRAM over AXI, which can be accessed via memory mapped IO registers.
... and Microblaze and ...
The MicroBlaze is a soft CPU running inside the PL and it can get direct access to a BRAM by simply connecting it to one of its busses, which can, of course, be AXI.
... inspect the SDRAM with the SDK debugger?
You can use the SDK debugger to inspect SDRAM when it is connected to the CPU you are debugging.
Could the SDK debugger look at the AXI BRAM controller memory space directly?
Yes, this is also just memory addresses and as long as it is mapped into the CPUs memory space you can access it.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Voyager
Voyager
Really depends on the FPGA, but assuming that the device in question has a BSCAN element (Boundary-Scan User Instruction) then you can attach this (together with a small logic) to a BRAM port and read out (or modify) the content via any JTAG cable.
Note that this will require that the BRAM port is either dedicated to the probing or can be switched between 'normal operation' and 'probe read-out'.
As far as I know, there is no out-of-the-box solution available with the Xilinx tools, but I might be wrong here.
Hope this helps,
Herbert
It's artix 7 XCA75T.
Frank
 If I do write in C, I do have the chance to use the SDK debugger in the SDK and inspect SDRAM. I do have SDRAM on my board, but so far I am not using it yet and I am not using the SDK either yet. I am just wondering if I can somehow use the SDK with Microblaze without much additional logic.
Frank
I made a typo in my last post. it is a XC7A75T.
Voyager
Voyager
If I do write in C, I do have the chance to use ...
I presume you are talking about C code for a soft-cpu (like the MicroBlaz) or do you plan to utilize HLS and design the logic with C too?
 I do have SDRAM on my board, but so far I am not using it ...
SDRAM is not BRAM, but you can probably use both and also inspect both with a little extra logic in the FPGA.
A soft-cpu can certainly access RAM content (BRAM, SDRAM) if designed properly and a remote debugger will also give you the desired access via the JTAG programming cabe, but it all depends on what you plan to do ...
Best,
Herbert
I know BRAM is not SDRAM. Would the simplest technique be to copy from BRAM to SDRAM with AXI BRAM controller and Microblaze and inspect the SDRAM with the SDK debugger? Could the SDK debugger look at the AXI BRAM controller memory space directly?
Frank
Voyager
Voyager
Good! :)
Hope this helps,
Herbert
