mrunal9
virtex II pro
What is the maximum frequency that can be applied to virtex II pro xc2vp70 (device 1704)? How to use the DCM for working at higher frequencies on the virtex II pro xc2vp70 (device 1704)?
Tags (3)
htsvn
Check the DCM Switching Characteristics in the page 44 of V2P Datasheet.
http://www.xilinx.com/support/documentation/data_sheets/ds083.pdf
Do check the speedgrade to know the range of DCM.
Thnx
mrunal9
Hello, Thank you for your help. But it has not solved my problem. I wanted to know that what is the maximum frequency that can be practically applied to virtex II pro xc2vp70 (-71704 device).
htsvn
Do you mean the max frequency at which the design runs?
If this is the case, then check the timing report to see it.
Thx
