sam025023
vivado 2015.1 simulation error (Failure: ERROR:add_1 must be in range [-1,DEPTH-1])
Hi there,
I tried to use vivado 2015.1 to run behavorial simulation for my own IP at the top level.
The systhnsis and implementation succeeded. Then I ran the functional simualation with default simulation settings.
I also used the same test bench to run the simulation, but previously it worked. The difference is that I added FIR compiler IP here.
  FIR_Filter FIR_filter_decimator (
.aresetn(DAQ_resetn), // input wire aresetn
.aclk(sys_clk), // input wire aclk
//// Inbound slave AXIS stream
.s_axis_data_tvalid(s_axis_data_tvalid_dye_FIR), // input wire s_axis_data_tvalid
.s_axis_data_tready(s_axis_data_tready_dye_FIR), // output wire s_axis_data_tready
.s_axis_data_tlast(s_axis_data_tlast_dye_FIR), // input wire s_axis_data_tlast
.s_axis_data_tdata(s_axis_data_tdata_dye_FIR), // input wire [63 : 0] s_axis_data_tdata
//// Outbound master AXIS stream
.m_axis_data_tvalid(m_axis_data_tvalid_dye_FIR), // output wire m_axis_data_tvalid
.m_axis_data_tready(m_axis_data_tready_dye_FIR), // input wire m_axis_data_tready
.m_axis_data_tlast(m_axis_data_tlast_dye_FIR), // output wire m_axis_data_tlast
.m_axis_data_tdata(m_axis_data_tdata_dye_FIR) // output wire [63 : 0] m_axis_data_tdata
Hereby the error messages I got from the vivado Tcl console:
Time: 35 ns Iteration: 2
$finish called at time : 35 ns : File "***/Data8**_v1_0.v" Line 861
INFO: [USF-XSim-96] XSim completed. Design snapshot 'TB_data_mover_bridge_behav' loaded.
INFO: [USF-XSim-97] XSim simulation ran for 1000ns
launch_simulation: Time (s): cpu = 00:00:11 ; elapsed = 00:00:59 . Memory (MB): peak = 1808.762 ; gain = 4.176
run 10 us
Warning: NUMERIC_STD."=": metavalue detected, returning FALSE
Failure: ERROR:empty_1 and not_empty_1 are inconsistent
I checked line 861 in the source file, it seems ok.
Any ideas?
thx
Sam
debrajr
This is issue with the testbench where in the process which drives the clk signal cause a clock event at 0 time which causes an issue with the counter add_1 in FIR IP. The solution is to rephrase the clock process in your testbench below:
always
begin
#(CLK_PERIOD/2) clk <= ~clk;
end
TO
always
begin
 clk = 1'b1;
 #(CLK_PERIOD/2) clk = 1'b0;
 #(CLK_PERIOD/2);
end
With this the error shouldnt happen.
Debraj
vuppala
Hello Sam,
Is it possible to share your testcase here to debug the issue?
Check how add_1 is declared in your code and its range?
Vinay
sam025023
Hi Vinay,
There is  add_1 is declared in my project.
Hereby the FIR ip and test bench files FYI.
I tested the ip with Vivado 2015.1 and win7 64bit. What I found is that the direct cause is the input of s_axis_data_tvalid to the FIR ip. If this pin is kept at low or high  all the time, there is no simulation errror.
Please take a look. thx.
Sam
debrajr
always
begin
end
TO
always
begin
 clk = 1'b1;
 #(CLK_PERIOD/2);
end
Debraj
hutchid
I also had this error but the fix suggested by debrajr did not work.
s_axis_data_tvalid was not driven at startup in my design, once I changed this I was able to Simulate
Hopefully this helps somebody else
prashanth453
hi all,
I am got the same error while simulating the FIR compiler in vivado 16.2.before fir compiler i have dds and cic working fine but after adding the FIR Compiler only it shows the simulation was stoped.
Time: 77500 ps Iteration: 1
$finish called at time : 77500 ps
please help me out in this regard
amahpour
This actually can mean that anything in your FIR compiler could be undriven. It could be an incorrect hookup (i.e. misnamed variable) or an actual undriven net.
The best way to test this is to drive a constant (e.g. 1'b1 or equivalent depending on bit width) into the module and verify where it runs and where it fails.
In my case I just had a misnamed variable.
