vivado 2016.1 xelab sometimes extremely slow
After the mixed-language DPI bug is fixed in Vivado 2016.1 (see post) I port all my test benches to Vivado.
However, I see sometimes that xelab is extremely slow. Here the numbers for some straight forward behavioral simulation models:
  • a simple test bench:                                                   2.5s
  • a modest test bench using DPI:                               7.1 s
  • a little bit larger test bench, also using DPI:    13m9.6s (!)
  • another test bench, also using DPI:              32m19.2s (!)
In other simulators it takes 10-15 seconds to build these test benches.
When looking at the console I see
    Completed static elaboration
    Starting simulation data flow analysis
    Completed simulation data flow analysis    <-- runs fast up up to here
    Time Resolution for simulation is 1ps      <-- over 10 sec to come
    Compiling package std.standard             <-- libs, take many seconds each
    Compiling package ieee.std_logic_1164      <-- from now every step at snails pace
So up to 'simulation data flow analysis' all seems fine, and afterwards is slows down dramatically. It takes a long time for the needed libs to compile, in other cases that's very fast. The compilation of the individual modules afterwards take many seconds per module, even when they are almost trivial. 100% of a single CPU is used.
If one has the patience to wait for xelab to finish one gets a nicely working model, no functional issues seen (so far).
That's Vivado 2016.1 under Ubuntu 14.04 LTS.
Any hint help highly appreciated.
With best regards,  Walter
Tags (3)
Hi @wfjmueller
Can you please provide and the steps to reproduce the issue for us to look into?
Thanks,Vijay
Hi @vijayak
I've checked whether the slowness depends on either DPI usage or mixed langage. Both doesn't seem to be the case, a hacked model with only vhdl sources was still very slow.
I've attached an example, code is from an open source project. Just unpack the tar ball and run 'build.sh'. Alltogether 17000 lines of vhdl code, but lots of libs and comments. Takes about 7 minutes in xelab.
Final notes:
  • I'm aware of the VRFC 10-516 warning, no functional problem, but must be cleaned up.
  • the model, when build, is not of much use without the co-simulation part which is not included
  • the tar ball is only to document the slowness of the xelab step
Hi @wfjmueller
Thanks for the design. I will check and getback to you.
Thanks,Vijay
any news about this?
I am having the very same problem with a VHDL design. The funny thing is elaborate is taking ages (>10 minutes) to compile even the VHDL standard libraries on a powerful PC (i7 Octa 16 GB RAM):
  Compiling package ieee.std_logic_arith
  Compiling package ieee.std_logic_unsigned
Then, when it reaches my design files, it takes very long for trivial files, as initial reporter mentioned.
This is making it very hard to switch to Vivado Simulator, which otherwise looks like a very good option.
Thanks!
Hi @vijayak
apparently I'm not alone with this issue, see last posting of @victorlopez.
Did you manage to at least reproduce the issue ? Any more info needed ?
Hi everybody,
I'm also experiencing this issue.
I'm using Vivado to co-simulate a project written in C++ and synthesized with Vivado HLS.
I tried both Vivado 2015.4 and 2016.1, but the behaviour is the same: the xelab compilation phase may take up to 30-45 minutes for a set of relatively simple files.
The strange thing is that for some designs the compilation is quite fast and doesn't take more than a couple of minutes, while for others the issue appears.
I tried some tweaks to the design's C and RTL codes, but, up to now, I couldn't find what is causing this behavior (e.g., using specific IEEE libraries, instancing AXI for the I/O ports, etc.).
I also noticed that the actual simulation phase seems pretty fast (couple of minutes for the design I'm currently debugging).
This is seriously limiting my ability to use the Vivado simulator to perform any verification task.
I hope someone in Xilinx will give an answer soon.
Even a temporary workaround could be acceptable, until they fix it in a next release.
Giacomo
@vijayak
just installed 2016.2. I see no improvement in the 'slow xelab' issue, for one modest design I get as time to build a behavioral simulation model
    vivado 2016.2: real 7m05.768s user 7m03.907s sys 0m0.628s
    vivado 2016.1: real 7m19.046s user 7m12.553s sys 0m0.732s
As also mentioned by @gmarchiori and @victorlopez: it be great if this gets fixed !
@vijayak,
Did a few more tests with vivado 2016.2 (under Ubuntu 14.04 LTS)
Compared the test benches for 4 different designs, either in behavioral simulation or in post-synthesis functional simulation (done with a model generated in vhdl). The size of the test benches is
             DPI   --- behavioral ---     -- post-syn func --
                   #ent  #ins   lines     #ent   #ins   lines
  serloop1    no     34    48    8350       45   1008   16768
  rlink      yes     64   100   15980       84   3281   51096
  sram       yes     64   116   16334      101   3021   45992
  w11a       yes    113   212   35422      162   8845  142555
where
#ent -> number of entities
#ins -> number of instantiations
I get the xsim compilation times (sum of xvhdl, xvlog, xsc and xelab time):
                -------  2016.1  -----       -------  2016.2  -----
               behavioral  post-syn-fu      behavioral  post-syn-fu
    serloop1    0m01.394s    0m14.064s       0m01.423s    0m15.648s
    rlink       0m05.266s    0m51.844s       0m04.579s    0m40.205s
    sram        9m12.601s  147m54.592s       9m08.565s  152m29.101s
    w11a                                    25m28.828s  355m45.069s
 while 'serloop1' and 'rlink' compile reasonably fast for both behavioral and post-synthesis the 'sram' model, even almost same size as 'rlink', is much slower. Using DPI does not seem to be the culprit. The some larger (but on an absolute scale still very modest sized) 'w11a' model gives compile times which are absurd, almost 6 hours for post-synthesis !
The problem is xelab. When looking at post-synthesis models one sees lots of
  Compiling architecture lut6_v of entity unisim.LUT6 [\LUT6(init="...]
  Compiling architecture lut4_v of entity unisim.LUT4 [\LUT4(init="...]
lines, and it takes several seconds per lut.
Bottom line is
  • Something very basic is broken here
  • using DPI does not seem to be the culprit (DPI crashed xelab in 2015.4...)
  • this makes the vivado simulator essentially unusable except for quite simple cases
