vivado 2018.3 simulator crash
In vivado 2018.3, I'm taking a core dump when launching simulation (windows 10, 64-bit).  It worked fine before restarting my pc.  Vivado just closes.  hs_err_pid6068.log says:
# An unexpected error has occurred (EXCEPTION_ACCESS_VIOLATION)
Stack:
no stack trace available, please use hs_err_<pid>.dmp instead.
hs_err_pid6068.dmp is attached.  Any help would be appreciated.
Re: vivado 2018.3 simulator crash
Hi cpawlowski@planetiq.com ,
It seems to be a corrupt project issue to me as I have executed reset_project command from the Vivado TCL console and then running simulation launched simulation without any crash.
Can you please share the archived project or the test case to reproduce this issue at our end.
Also, please try running simulation on an example design and check. This will help us to narrow down if the issue is project specific or not.
Thanks & Regards,
Sravanthi B
I can't post the archive project on an open forum, but I can send it directly to a contact at Xilinx.  Please let me know who to send it to.
Other notes... the design still synthesizes & implements without issue.  Example designs (and other projects) simulate without issue, so I think the installation is not corrupted.
I had sent you an EZMove package where you can upload your project there and send it back to me. We will look into it and will get back to you once we find the root cause of this crash.
That did the trick... thank you!
