vivado ip simulation model for modelsim
Re: vivado ip simulation model for modelsim
The below forum posts and Answer Records are having some useful information with respect to your query
http://forums.xilinx.com/xlnx/board/crawl_message?board.id=SIMANDVERIBD&message.id=6479
http://forums.xilinx.com/xlnx/board/crawl_message?board.id=SIMANDVERIBD&message.id=11375
http://www.xilinx.com/support/answers/56083.html
http://www.xilinx.com/support/answers/58333.html
http://www.xilinx.com/support/answers/56692.html
i use this http://www.xilinx.com/support/answers/56083.html to generate modelsim .do, and copy the script i needed, modified for designated folder for correct library etc.  when running vcom several file still complain its protected.  however the instantitate IP did compile without issue, but when running sim, the IP is blank, there is no signal/IO, nothing, just blank.  I guess becase previous error about protected region, the IP didn't compile into modelsim.  anyway to vcom without these issues?
i'm using 2013.3, 10.3b PE.
