Visitor dannna
vivado simulation - block memory module failure
I'm simulating a project with my own IPs. one of the IPs has a block memory generator (8.2).
The simulation stops after 35 ns and tck message:
Block Memory Generator module TOP030815.design_1_i.golgol_0.U0.blk_mem_gen_GOLAY_inst.inst.native_mem_module.blk_mem_gen_v8_2_inst is using a behavioral model for simulation which will not precisely model memory collision behavior.
Failure: ERROR:add_1 must be in range [-1,DEPTH-1]
Time: 35 ns Iteration: 2
$finish called at time : 35 ns : File "../../../project_1.srcs/sources_1/ipshared/ornim.medical/golgol_v1_0/a6138b30/hdl/golgol_v1_0.vhd" Line 93
xsim: Time (s): cpu = 00:00:05 ; elapsed = 00:00:34 . Memory (MB): peak = 980.820 ; gain = 37.723
INFO: [USF-XSim-96] XSim completed. Design snapshot 'TOP030815_behav' loaded.
what is the problem?
Danna
Re: vivado simulation - block memory module failure
Did you use the AXI4 interface for the block memory generator IP?
This kind of failure is typically seen when master and slave AXI are not initialized. e.g. when the slave TVALID and TDATA are in an 'U' or 'X' state.
You need to firstly examine the testbench (or the AXI bus drivers) and ensure they're all initialized.
For instance,
  -- Data slave channel signals
  signal s_axis_data_tvalid              : std_logic := '0';  -- payload is valid
  signal s_axis_data_tready              : std_logic := '1';  -- slave is ready
  signal s_axis_data_tdata               : std_logic_vector(15 downto 0) := (others => '0');  -- data payload
  -- Data master channel signals
  signal m_axis_data_tvalid              : std_logic := '0';  -- payload is valid
  signal m_axis_data_tdata               : std_logic_vector(23 downto 0) := (others => '0');  -- data payload
Visitor dannna
I'm using a native block memory and not an AXI interface,
Also, check the clock stimulus in testbench. Take the following stimulus for example,
process begin
clk_153m <= not clk_153m;
wait for clk_cyc_153m / 2;
end process;
The clock edge is occurring before the register initializations have propagated to all connecting signals.
The solution is to rephrase the clock process such that the wait statement occurs before the toggle of the clock signal.
process begin
end process;
Debraj
@danna Is the issue closed based on the suggestions provided? If you have a solution you can post it and close this thread.
Debraj
@dannna,
Didi you find the solution for this problem.
I am going through the same problem now.
Sean
