marsmoon
vivado2014.4 use which version of modelsim
  I'm using vivado2014.4 and the UG973 tell me I can use following tools from Mentor:
      1.Mentor Graphics Questa SIM SE/DE (10.3b)
      2.Mentor Graphics Questa SIM PE (10.3b)
      3.Mentor Graphics Questa Advanced Simulator(10.3b)
  Does this also mean Modelsim version is at least 10.3b?
Best Regards.
pratham
@marsmoon 2014.4 UG was bit misleading. as pointed by @ashishd 10.3b modelsim and newer version are supported. You can also refer 2015.1 and above where modelsim is explicitly mentioned in the UG
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug973-vivado-release-notes-install-license.pdf
-Pratham
ashishd
Hello @marsmoon,
Yes you are right. This means that 10.3b and the later versions are supported.
Ashish
pratham
-Pratham
nupurs
Hi @marsmoon,
Yes, the minimum version of Modelsim supported in Vivado 2014.4 is 10.3b.
Nupur
Accept as solution if it resolved your query, give kudos(star on left) if it led you to the solution.
Nupur
