vopt switch
I'm running Vivado 2017.4 with QuestaSim 10.6a. When I export simulation, the elaborate.do file has the -64 switch on the vopt command. Is there a way to disable that? QuestaSim complains about it and I would rather not edit the generated files if I can avoid it.
What message did you receive from Questasim regarding the -64 switch?
The error is
** Error: (vsim-3816) Optimized design "isb_tb_opt" cannot be used by this version of the simulator - it was only compiled for a 64-bit version of vsim
my vsim command is: vsim -t 1ps -lib xil_defaultlib isb_tb_opt
if I add the -64 switch to it as follows: vsim -64 -t 1ps -lib xil_defaultlib isb_tb_opt
I get the following warning before the error mentioned above
** Warning: (vsim-159) Mode option -64 is not supported in this context and will be ignored.
Generally, for 64-bit modelsim toolset, the commands should work fine (vopt -64 and then vsim).
This error indicates the optimized design failed one of several version checks.
What if you edit the script and remove the -64 switch?
Thank you for the reply. It works when I edit out the -64 switch. I can run the *.sh script the export simulate command generates; without modification; with no issue. I want to run the vsim command from the GUI in questa which is proving bothersome. If I can have vivado export the sim scripts without the -64 switch, it will make my life easier. I unable to edit the tcl command in the export sim dialog box in the GUI, where I could add the -32 switch. I am going to try to do the sim export purely in TCL, but if there was a GUI option that I could set, it would be more convenient. Again, I appreciate your help.
