what are the equivalent vivado synth tcl command for -y and +incdir option of vlog(Mentor Questa) ?
Hi Friends,
I am using Non-Project mode.   I will get  the RTL file list that is compatible to Mentor Graphics Questa(vlog and vsim cmds).   I am remodifying the RTL file list to vivado synthesis compatible.
In the given file list i have seen many -y and +incdir options are there for ,
-y for searching files with mentioned extention (in the files list itself added the file extention as *v , *sv etc)
+incdir+ for searching for include files
1) What tcl commands we have to use for satisfying the above functionalities ?
Any help or suggestion is highly appreciated.
-Sam
what are the equivalent vivado tcl command for -y and +incdir option of vlog(Mentor Questa) ?
-Sampath
Re: what are the equivalent vivado tcl command for -y and +incdir option of vlog(Mentor Questa) ?
synth_design has an option  -include_dirs which specifies the directories to search for Verilog `include files.
There's no equivalent -y option. You need to read all required source files via read_verilog prior to synth_design in non-project mode.
HI @ssampath ,
We need to use the -y and +incdir with the vlog command. (Ex:- vlog -y <path> +incdir <path>)
You can use the same command as shown in the above example in your script if you are using Questasim.
Are you looking for the replacement of the above switches in Vivado XSIM ?
Thanks you @shameera ,
No, I am modifying the RTL file list for vivado synthesis not for simulation. I want vivado synth commands which are equivalent to vlog -y and vlog +incdir.
-Sam
-Sampath
HI @graces ,
you are correct there is equivalent command, but we can do it in the following way,
we can use tcl foreach
foreach file [glob read_verilog -sv /RTL/../arm-download-3200949/TM100-BU-50000-r3p2-50rel1/coresight_soc/shared/logical/cxctm/verilog//*v] {
read_verilog $file
-Sampath
-Sampath
